LCD Gauge Screen for our trucks?
I've seen some cool monitors for the newer diesels that show a bunch of different readings at once like EGT, Pressures, Boost etc. Do they make a gauge screen for the OBS guys?
Thanks! |
Originally Posted by fordpride
(Post 15271798)
Ts sells a monitor that goes with theirchip and iI believe you can switch tunes through it.
This is what just got my money, and so far it has been great. Even works as a code scanner and data logger. DP -Tuner
I have an Edge Insight that displays eight engine/transmission data points on the screen at one time. These data are selected by the driver from over 20 available for viewing. The driver can select any of them as he may wish. The instrument also reads trouble codes. I like it.
