1995 f150 5.8l crossover pipe (y-pipe) help
I've got a 1995 f150 351 4x4 extended cab short bed automatic that is annoyingly loud because it needs a new crossover pipe and whole new exhaust. I found one on summit for $57 but it says it's for a 1980-81, was wondering if this would work on my truck because I'm not paying the $300 bucks for the bassani one with the cat on it. If this one doesn't work what are some others that will?
Here's the link: http://www.summitracing.com/parts/wl...FYNAaQodWVAAsQ Also it appears that the manifolds are studded to attach the y pipe, is this correct? I am 95% sure the bolts are going to break off when I go to remove the old y pipe. Do I need to get new manifolds too or do the bolts/studs hammer out? Or can I drill all the way through the manifold where the bolts/studs are and just run new bolts? Any help would be greatly appreciated, thanks in advance guys!:-X22 |
I have never run across that y-pipe before. I question whether it really fits a Windsor or not. There is mention it fits the 6.6L engine of that time period which is a 335 series engine that has very little in common with a Windsor. There was a de-stroked version of the 6.6L(400ci) 351M that shares the same cubic inch as the 351W, but once again it's a very different engine.
Why not get the Walker y-pipe that is supposed to fit? Walker 15849 http://www.summitracing.com/parts/wlk-15849/ It's a little cheaper here: RockAuto WALKER Part # 15849 Plus if you venture down to the vendor area there is a discount coupon available. Search on RockAuto....a site sponsor! |
