1978 Ford F250 400 oil pan
Hey everyone... I spent the past couple of hours searching old posts, and couldn't find anything on the topic. - Apologies in advance if my search wasn't sufficient.
I need to order a new oil pan from LMC truck, as I don't have a ton of time to go to a bunch of junk yards to pull one. They have two oil pan options for the 1978 F250: 40-4608 (1) Oil Pan w/ Plug 240 300 4WD F-Series 73-79 40-4606 (1) Oil Pan w/ Plug 351M 400 2WD F-Series 77-79 Which one can I use to replace what I have? I have a 4WD 400, which apparently isn't an option. Thanks for any help you can provide! |
Originally Posted by MinesRugger
(Post 15015239)
Thanks Bud. That's what I thought - I didn't think the drivetrain had much to do with the oil pan, but I wanted to make sure before I plunked down some cash!
(Post 15015500)
I'm pretty sure its a front sump. I'll post some photos once I get to the appropriate number of posts...
(Post 15015543)
https://cimg3.ibsrv.net/gimg/www.for...12dbcaa73e.jpg
This is a picture taken from the front underneath of the truck. You can see the holes in the pan around the plug, and to the left of the plug. Oil filter on the right. https://cimg4.ibsrv.net/gimg/www.for...7eff2c0b98.jpg This is a photo taken from the passenger side, looking down from above into the engine compartment. You can see the top passenger side of the oil pan, basically exploded. No idea how that happened. |
Originally Posted by Bud Mud
(Post 15015555)
if your truck has a front sump now than either will fit. :-X22
(Post 15015564)
If either will fit, which should I pick??? Ahhhh so many options! :-huh ;)
Oil pan
Hello
I seen a used oil pan on E-Bay for 351m-400 has the screw in dipstick. Good Luck |
It kind of looks like a connecting rod broke on it, pull the spark plugs directly above the hole on both sides of the engine and put a long wire in each plug hole and see if the pistons are moving by turning it over by hand.
I guess if you shine a light in the hole you might be able to look also
