I came to the conclusion that it's all a crap shoot. I thought about new calipers (already got pads, Akebonos) but since I can't demonstrate that any pistons are sticking and there were no slides sticking or bound up rattle clips, a different approach is being taken.
Went to a JY and got two low mile, damage free LH caliper brackets off of Explorers. Both were wearing the pads normally. JY brackets because, the A1 Cardone rebuilds were made from lousy cores that should have been scrapped. Cleaned up the JY brackets using brake cleaner, 320 sandpaper in the bores, q-tips and plenty of brake cleaner. Assembled with Cerami-glyde and all new hardware. Turned rotors. Assembling. Will be done today, time will tell. It really would have been nice to find an actual, in-my-face reason for the (tapered pad wear) problem then fix it rather than find nothing conclusive that would cause it, and go on a wild goose chase and in the end, research to death, find no wild new ideas (I kinda figured there would be any), build it buy the book hope for the better. |
Quote:"the A1 Cardone rebuilds were made from lousy cores that should have been scrapped. "
How do you tell they should have been scrapped vs being re-buildable? tom |
Originally Posted by CBB9M
(Post 14878138)
Went to a JY and got two low mile, damage free LH caliper brackets off of Explorers. Both were wearing the pads normally. JY brackets because, the A1 Cardone rebuilds were made from lousy cores that should have been scrapped. Cleaned up the JY brackets using brake cleaner, 320 sandpaper in the bores, q-tips and plenty of brake cleaner. Assembled with Cerami-glyde and all new hardware. Turned rotors. Assembling. Will be done today, time will tell. It really would have been nice to find an actual, in-my-face reason for the (tapered pad wear) problem then fix it rather than find nothing conclusive that would cause it, and go on a wild goose chase and in the end, research to death, find no wild new ideas (I kinda figured there would be any), build it buy the book hope for the better. Will be interesting to hear how it goes, so keep the forum updated on this thread. |
Originally Posted by tomw
(Post 14880110)
Originally Posted by Lippy
(Post 14885254)
Hi guys, I work at Cardone.
CBB9M, Where did you purchase your brackets? Is it possible they gave you a core instead of a new part? All of our brackets are cleaned and inspected when they come in as cores. They are also checked to be sure all that all the critical areas such as threads, dimensions and distances are the same as what the O.E. requires for the application. If any of these areas are not within spec, they are not used and are scrapped. |
