Do I need to replace ICP pigtail along with the new sensor
Hi all, I was in the midst of replacing leaky HPOP orings, new GPR, new water-drain oring, etc with my 7.3 when I noticed that my ICP sensor was leaking too.
The truck ran before I opened up this can-o-worms, but my questions are these. Do I need to replace the ICP pigtail too? There was oil inside of the connector, but given that the truck ran before disassembly, should I anticipate any problems? Thanks in advance as the knowledge of everyone here is saving me and others tons of dough! DBall |
Just clean it out and reinstall. That way you will know if the new one leaks in the future.
Originally Posted by Bonanza35
(Post 14790853)
Also, use a mild cleaner that won't deteriorate the plastic and insulation such as one designed for electronics. A dab of dielectric grease at the opening will help ensure water doesn't get in as well. |
thanks guys, i'll report any problems i may encounter.
