Cam sensor bank 1
Truck is an 08 with the 5.4 flex fuel with about 150k on the clock
Well this morning I started my truck ad made my 25 mile commute to work and noticed it sounded allot throatier than normal I wasn't complaining at that point I figured I blew out the muffler. but after I had my material for the day I started my truck back up to find a CEL. Truck is running codes P0340 and P0344, passenger side cam sensor. I followed a few guides and so far I've: -taken out the sensor cleaned it and ohm'd it out, it seems to be in spec +/- 400 ohms - checked dc to the sensor seems to be 0.3 volts dc - checked AC out seems to be between 0.5 to 1 volt AC - had continuity to ground on the ground pin however I did find the alternator voltage to be a tid bit low, under 14 volts running. Well I'd hate to replace the alt if that's not the issue because that being the cause seems pretty rare and I find it unlikely the truck skipped timing (had chains and tensioners done 40k ago) Truck does have the typical phaser knock, I gave up on trying to fix that 50,000 miles ago. any ideas on where to go from here? Edit: also the codes appear to come back as soon as I reset them. |
Sounds like a Phaser issue . A VVT solenoid may help . I have had luck before with replacing the solenoids . Best of luck !
Originally Posted by JWC 3
(Post 14776945)
I"m going to swap out the sensor and see if that does it. any ideas on how to see if the alt is putting out AC, my meter didn't find anything and the oscilloscopes I have access to really aren't the right type (radio testing) |
If into electronics , you should know the lack of quality of today's parts . 50 K of service can kill anything . Do you have a Fluke ? It should show AC problems . Another thing . How is your oil and filter quality . They make a huge difference in VVT performance .
(Post 14777091)
oil and filter are motorcraft with a bit of lucas(seems to shut up the phasers a bit), changed around every 3k since I've owned it. I plan on popping the valve cover off tomorrow to see what it looks like. |
so for S&Gs I switched the sensors to see if it'd follow the sensor, nope.
I put a tone and sniffer on the wire back to the pcm found the pin and ohmed it out to be about 0.2 ohms, I'm not sure if that's in spec or not (I can't seem to find any figures on it) also had the alt tested 54mV ripple, unfortunately I can't tell how the trace looks by the print out. Well I have no clue what it could be at this point, I really doubt it skipped a tooth on the timing chain because wouldn't I instantly get an advance/retard code. |
