Drive shaft bolt torque
I plan on removing the aft drive shaft on my 1998 4x4 auto 4.0 Ranger to lube the slider.
What is the torque on the bolts that attached to the trans output and the read axle input flange? Thanks |
torque
I GOT IT OFF tsb 03-04-8
82 AND 83 FT LBS |
Some more information for you: Ranger Slip Yoke Lube
Do you plan to use any torque lube or not?
