VIN info. on my 2009 F-350
I purchased from dealer but would like more info.
VIN - 1FTWW31539EA83265 |
Here ya go:
Originally Posted by Ford ETIS
Primary Features
Build Date: 27.03.2009 Vehicle Line: F250/350/450/550 Super Duty Body Style: Double Cab (3/4 Door) Version: 350 Series Engine: 5.4L 3V V8 Transmission: 5R110W 5 Speed Auto Trans NAAO Drive: LHD 4WD (PTD) Axle Ratio: 3.73 Emission: With 49 State/Non Green State Req Air Conditioning: Manual Air Conditioning Paint: Sterling Grey Metallic W/B Minor Features Medium Stone Interior Marta Less Front Fenders Decal-4X4 Less O/Rd Srw Silv Met Tailgate-Black Handle Centre Latch With Tailgate Lock With 8' Styleside Box-Steel 4 Cargo Tie Down Hooks - Inside With Load Box Edge Protectors Less Pickup Box Extender Less Load Box Bedliner With Base Payload Package 172"/4369MM Wheelbase XLT (-) Version Packages Kentucky Truck Plant Build Security Lock Group With Snowplow Pack 11,000 LB. GVW Less Appearance Group Less Exterior Appearance Pack With Power Equipment Group Less Memory Package Feature Content Group 1 Kentucky Truck Plant Build Only With English Language Label Owner Hand Book Pack Brand Owner - Ford With 2 Ton Mechanical Jack With Power Front Windows With Electric Rear Windows With Privacy Glass With Fixed Rear Window Less Overhead Console Less Floor Mounted Console Adjustable Accl/Brake Foot Pedals Front Floor Carpet Mats With Carpet Floor Covering I/P Insert - Level 1 Sunvisor - Single Driver W/Strap With Sunvisor Mirror - Passenger With Level 3 Door Trim Panel With Bright Front Grille Less Exterior Wheel Lip Moulding Less Lower Body Moulding Less Side Auxiliary Step Electrochromic Mirror-Mic/Mgm Com Telecsp TT Pwr Htd Lighted With Black Exterior Mirror Less Temp Control Driver Seat Less Temp Control Passengers Seat 2nd Row Seat 60/40 (3 P) - Folding With Driver 6 Way Pwr.Seat Adjuster With Pass 6 Way Power Seat Adjuster Trailer Tow Prep Pack Trailer Tow - Class III Receiver With Front Towing Hook Exterior Door Handle - Black Double Cab (3/4 Door) With Central Locking System With Door Entry Remote Control Unit With Remote Keyless Entry Less Sun Roof Less Tu-Tone Accent Colour Less Body Tu-Tone Paint Front Bumper - Steel Chromed Rear Bumper - Steel Step - Chromed With Front Licence Plate Bracket With Driver Air Bag With Passenger Air Bag Adjustable'D'Ring-Drivers Seat Belt Less Passenger Air Bag Deactivation With Adjustable 'D' Ring Pass Seat With Frame Mounted Tyre Carrier With Conventional Spare Wheel Std Duty Dual Front Shock Absober With Standard Rear Shock Absorbers With Single Rear Wheels With 8 X 18" Chrome Steel Wheel LT 275/70R18E A/T BSW With Bright Wheel Hub Cover Less Engine Idle Shutdown Timer Less Immersion Heater With 49 State/Non Green State Req With Monobeam Suspension - Narrow Less Stabilizer Package Less Attitude/Ride Height Pack With Standard Duty Front Suspension With Front Stabilizer Bar Single Leaf Rear Auxiliary Spring Less Rear Stabilizer Bar Less Rear Axle Package 3.73 Rear Axle Limited Slip Differential 5.4L 3V V8 With Catalyst Less Exhaust Pipe Extension Power 4-Wheel Disc Vacuum Boost Integrated Brake Control 4 Wheel Anti-Lock Braking System Less Engine Traction Assist Normal Fuel Fill Less Fuel Kit - FIA Less In-Dash Internet Device-FIA Less Tracking System - FIA Less Remote Starter - FIA Less Transmission Power Take Off Electric Trans Case And Auto Hubs Less Skid Plates With Mid-Ship Fuel Tank Non Locking Fuel Cap With BP Label For Unleaded Fuel Less Diesel Fuel Content With Steering Damper With Tilt Steering Wheel Leat/Red Cont/Audio/Crse/MGM Wheel With Speed Control Less Auxiliary Heater With MPH/KMH Speedometer Tyre Inflation Monitor Instrumentation Pack Less Reverse Proximity Sensor With Perimeter Anti-Theft With Safeguard Anti-Theft Sys(Pats) Standard Duty Battery Heavy Duty Alternator With AM/FM CD Player With NAAO Radio Frequency With A/V Jack Analogue Audio Broadcast Less Family Entertainment System With Media Gateway Module Less Camera Less Homelink Less Daytime Running Lamps With Aero Headlamps With Front Fog Lamps Less Roof Marker/Clearance Light Engine Compartment Light Tail lamps - Level 1 With High Mounted Stop Lamp With Automatic Headlamp Control Less Spare Accessory Switches Sterling Grey Metallic W/B Generic Country Group 1 350 Series F81A-5310-AHD (6000 LB.) F81A-5310-AHD (6000 LB.) #2 5R110W 5 Speed Auto Trans NAAO F250/350/450/550 Super Duty (+)"USA" (-)"N" (-) GVMT Service Administration (-)"CDN" (-)"GU" (-)"BRN" (-)"BZ" (-)"IS" (-)"ATG" (-)"IL" (-)"AW" Less Ultimate Package Less Fleet :) |
1 Attachment(s)
And here's your window sticker.:-X22
Thanks Tom
Hey Tom, new to the Super Duty pages, but interested to know if you can run my VIN as well 1FTSW21R59EA91511, thank you in advance.
F250/350/450/550 Super Duty, 6.4L Diesel V8 Twin Turbo, Oxford White
VIN Number: 1FTSW21R59EA91511 Primary Features Build Date: 17.04.2009 Vehicle Line: F250/350/450/550 Super Duty Body Style: Double Cab (3/4 Door) Version: 250 Series Engine: 6.4L Diesel V8 Twin Turbo Transmission: 5 Speed Auto 5R110W - HI/Torque Drive: LHD 4WD (PTD) Axle Ratio: 3.55 Emission: 50 State Emission Requirements Air Conditioning: Manual Air Conditioning Paint: Oxford White Minor Features Charcoal Black Interior Tech Less Front Fenders DEC-FX4 O/RD SRW Silver/Red Tailgate - With Flexible Step With Tailgate Lock With 8' Styleside Box-Steel 4 Cargo Tie Down Hooks - Inside With Load Box Edge Protectors Less Pickup Box Extender Less Load Box Bedliner With Base Payload Package 172"/4369MM Wheelbase FX4 Version (-) Version Packages Kentucky Truck Plant Build Security Lock Group Less Special Equipment Package 10,000 LB. GVW Less Appearance Group Less Exterior Appearance Pack With Power Equipment Group Less Memory Package Feature Content Group 1 Kentucky Truck Plant Build Only With English Language Label Owner Hand Book Pack Brand Owner - Ford With 2 Ton Mechanical Jack With Power Front Windows With Electric Rear Windows With Privacy Glass With Sliding Rear Window Standard Ovrhed Console & With Rail Less Floor Mounted Console Adjustable Accl/Brake Foot Pedals Front Floor Rubber Mats With Carpet Floor Covering I/P Insert - Level 2 Drvs Single Cloth Sunvisor W/Mirror Non Illum Covered Mirror-Pass With Level 3 Door Trim Panel Colour Keyed Grille W/Grey Insert Less Exterior Wheel Lip Moulding With Lower Body Moulding SD Aux Step-Curv Tube Cr W/O Lights Electrochromic Mirror-Mic/Mgm Com Dual Sail T'Scp TT Mirrors-Pwr/Htd With Body Coloured Exterior Mirror Less Temp Control Driver Seat Less Temp Control Passengers Seat 2nd Row Seat 60/40 (3 P) - Folding With Driver 6 Way Pwr.Seat Adjuster With Pass 6 Way Power Seat Adjuster Trailer Tow Prep Pack Trailer Tow - Class III Receiver With Front Towing Hook With Colour Keyed Ext Door Handle Double Cab (3/4 Door) With Central Locking System With Door Entry Remote Control Unit With Remote Keyless Entry Less Sun Roof Less Tu-Tone Accent Colour Less Body Tu-Tone Paint Front Bumper Painted In Bodycolour Rear Bumper Body Coloured Painted With Front Licence Plate Bracket With Driver Air Bag With Passenger Air Bag Adjustable'D'Ring-Drivers Seat Belt Less Passenger Air Bag Deactivation With Adjustable 'D' Ring Pass Seat With Frame Mounted Tyre Carrier With Conventional Spare Wheel Premium Off Road Frt Shock Absrbers Premium Off Road Rr Shock Absorbers With Single Rear Wheels 8 X 18" Premium Chrome Steel Wheel LT 275/70R18E A/T OWL With Bright Wheel Hub Cover Less Engine Idle Shutdown Timer Immersion Heater Engine 50 State Emission Requirements With Monobeam Suspension - Narrow Less Stabilizer Package Less Attitude/Ride Height Pack With Standard Duty Front Suspension With Front Stabilizer Bar Less Rear Auxiliary Springs Less Rear Stabilizer Bar Less Rear Axle Package 3.55 Rear Axle Limited Slip Differential 6.4L Diesel V8 Twin Turbo With Catalyst Less Exhaust Pipe Extension With 4 Wheel Disc Brake Hydro-Boost Integrated Brake Control 4 Wheel Anti-Lock Braking System Less Engine Traction Assist Normal Fuel Fill Less Fuel Kit - FIA Less In-Dash Internet Device-FIA Less Tracking System - FIA Less Remote Starter - FIA Less Transmission Power Take Off Electric Trans Case And Auto Hubs With Skid Plates With Mid-Ship Fuel Tank Fuel Cap - Non Locking Green With Diesel Fuel Capability With Low Sulfur Diesel Fuel Content With Steering Damper With Tilt Steering Wheel Leat/Red Cont/Audio/Crse/MGM Wheel With Speed Control Less Auxiliary Heater With MPH/KMH Speedometer Tyre Inflation Monitor Instrumentation Pack Less Reverse Proximity Sensor With Perimeter Anti-Theft With Safeguard Anti-Theft Sys(Pats) Heavy Duty Battery Extra Heavy Duty Alternator AM/FM CD Changer/Clock With NAAO Radio Frequency With A/V Jack Satellite Digital Broadcast Less Family Entertainment System With Media Gateway Module Less Camera Less Homelink Less Daytime Running Lamps With Aero Headlamps With Front Fog Lamps Less Roof Marker/Clearance Light Engine Compartment Light Tail lamps - Level 1 With High Mounted Stop Lamp With Automatic Headlamp Control Spare Accessory Switches-4 Oxford White Generic Country Group 1 250 Series F81A-5310-AGD (5600 LB.) F81A-5310-AGD (5600 LB.) #2 5 Speed Auto 5R110W - HI/Torque F250/350/450/550 Super Duty (+)"USA" (-)"N" (-) GVMT Service Administration (-)"CDN" (-)"GU" (-)"BRN" (-)"BZ" (-)"IS" (-)"ATG" (-)"IL" (-)"AW" Less Ultimate Package Less Fleet |
1 Attachment(s)
Originally Posted by chp10_8
(Post 14724752)
Just FYI, it's a publicly available resource that's hard to find. And they only have window stickers for trucks made in the last 5-6 years it seems. Paste this into your browser and put the VIN at the end: :-X22 |
That's awesome Tom, I am thinking of printing it and just sticking it back on the rear window again, haha.
it's good to see what all is exactly missing on the truck, might add a little accessories on there myself just to step it up a little bit! Thank you again for the research!!!! and the link |
