New Leaf Springs Ordered
Well I went to do the leaf spring bushings on the crew cab last thursday.... all the bolts frozen. Went to torch bolt heads off and then the shackle on the rear was basically rusted up, ended up just cutting everything off and ordered new springs and all shackles and hangers 600 bucks from general spring kc supposed to be here monday... hoping for good quality parts will let y'all know how that turns out.
Did you replace the rear spring hangers, the part that is riveted to the frame? I may be interested in one.
I've fought those bushings out of the front and the rear. It is a lot of cursing and hammer swinging. Keep us updated! |
Yea I torched one side off and the other side I used the air hammer, I didn't even take the spring loose from it those bolts though the spring are in there and the 1/2 impact wasn't makin them budge at all that's why I just cut the hangers off and ordered new ones
Those front hangers ain't to expensive 49$ a side
http://www.generalspringkc.com/Leaf_Spring_Shackles_Hangers_Ford_Truck_Van_s/2020.htm?searching=Y&sort=7&cat=2020&f-Hangers=2126&f-F350=2425&show=30&page=1&f-1997=2916 |
Let me know what parts you guys need. I can give you full kits with all grade 8 hardware and free shipping on components!
-Junior |
I hope you went ahead and ordered the SD springs for a Much better ride and better weight capacity
The ones I took off had 4 plus an overload the ones I ordered are 5 leaf plus overload and rated at 2810 lbs
Originally Posted by 1994F2507.3L
(Post 14697906)
I understand of you don't want to part with yours, I'll keep looking. Thanks! Junior, I'll be placing my order front springs soon. I'm enjoying the B codes I got from you! |
Oh its not that I don't want to part with them it's just that I haven't gotten them to separate from the spring j tried the impact and the Sawzall on one and it didn't do any good that's why I ended up cutting them out, I can take another look at it this coming week and see what I can do if I remember
Cut the shackle and send the mess to me, let me mess with it? I'll prepay shipping and send you the label.
Are you wanting the front hanger or the rear?
The very rear. The one that the shackle bolts to.
I could probably hook ya up with one a those yea
That would be awesome!
My RSK arrived today. I'll knock all the edges off to my liking and have it powder coated. I'll order the springs this week. When this is installed I expect my rear to be about an inch low and will be looking to get the rear shackle flip installed. Thanks, let me know how I can help! |
ill be back up at the shop tomorrow and if i get time between classes (Im an automotive major at UCM) ill get one hacked off, if not probably thursday evening. Send me an email and we can work out details. eclipsesps1607@gmail.com
