meangreen92 with some words of wisdom that I had to save for others to see. This covers an issue of blowing a fuse in the fuse block (top R/H #2 in the diagram) when you connect an aftermarket radio to the OEM connection improperly. And BTW the OEM connection is the green square plug.https://cimg4.ibsrv.net/gimg/www.for...1a32a31c30.jpg
https://cimg5.ibsrv.net/gimg/www.for...ed52d9cb46.jpg "Improper radio installation, the common mistake is to use the blue-with-red-stripe wire as a ground, since it shares a connector with the yellow switched-12V+ wire, and that will blow that fuse the first time you turn on the lights and hit the brake. That blue-with-red-stripe wire is for the dial light in the original factory radio, so if it gets grounded, it will pop that fuse." https://www.ford-trucks.com/forums/1...l#post17791311 |
2 Attachment(s)
A couple of new ones, thanks folks.
https://cimg5.ibsrv.net/gimg/www.for...5a750dea1e.jpg
None PDF version. And where to get the bushings/insulator. Thanks ND. 1) C6TZ-6A061-A .. T/C Insulator / Obsolete/Reproduced? NOS PARTS LTD in Waxahachie TX has 3 = 972-937-2201. ----------------------------------------------------------------- 1) C6TZ-6068-D .. T/C Insulator / Obsolete/Reproduced? GREEN SALES CO. in Cincinnati OH has 4 = 800-543-4959 CARPENTER NOS OBSOLETE PARTS in Concord NC has 10 = 800-476-9653. NOS PARTS LTD has 11. |
FYI: 1973/79 Ford Light Truck Parts Catalog available on a C/D from hipoparts.com
Did you buy a parts CD and need help figuring out part #'s ? https://www.ford-trucks.com/forums/1...-number-s.html Thanks mikeo0o0o0 |
https://cimg4.ibsrv.net/gimg/www.for...5ee02acab0.jpg
https://cimg5.ibsrv.net/gimg/www.for...f84596f270.jpg https://cimg6.ibsrv.net/gimg/www.for...3cdee9a59f.jpg https://cimg8.ibsrv.net/gimg/www.for...5e3a4fab88.jpg https://cimg9.ibsrv.net/gimg/www.for...adf6f5cf5b.jpg Sorry been a while since I added anything, Iv'e been busy and having trouble loading pics with the new changes. And as always thanks ND for the diagrams. |
3 Attachment(s)
Some new ones.
https://cimg2.ibsrv.net/gimg/www.for...b469bc1ed8.jpg
https://cimg5.ibsrv.net/gimg/www.for...6cf3a863ae.jpg I have to say I am very proud to know Alan personally and to see how far he has taken his dream of being a monster truck owner, driver and all around wildman. |
I just read thru this thread and realized this guy is really onto something and wanted to pass it along.
https://www.ford-trucks.com/forums/1...w-starter.html Take you time and really READ it and understand what he is explaining here. DO NOT be under the gun to get your truck fixed in 2 min. |
https://cimg7.ibsrv.net/gimg/www.for...d6ecd6441.jpeg
https://cimg3.ibsrv.net/gimg/www.for...dc312a154.jpeg 1978 F250 instrument cluster pin out location. thanks to scottscott 17 oil gauge 16 empty 15 gas gauge 14 IVR power 13 turn indicator 12 amp meter 11 amp meter 10 dash lights 9 ground 8 temp gauge 7 turn indicator 6 high beam 5 seat belt light 4 brake light 3 empty 2 empty 1 brake light |
Door seals with a metal strip in them (off a 86-90 ish Ford) seem to work better than glue on replacements. The ones with the metal strip have to be trimmed at the bottom corners and where the eventuaily come back together under the sill plate.
And another one..
https://cimg8.ibsrv.net/gimg/www.for...064f600b4a.jpg |
To put some shoulder belts in your truck you can get some belts and reels and mount them like in a 77-79 reg cab. Cutting the large hole in the cab wall to mount the reel. Or just mount the SC set up and only have to mount the 2nd shoulder point to the cab wall and put the reel on the floor.
https://www.morris4x4center.com/fron...ach-belt3.html |
