removed distributor and half a gasket fell out
Did ford use a gasket between the distributor and the block on the 223?
Short answer is Yes
Whats the long answer?
It was a fairly thin paper type!
There hasn't been one on mine in the past 30 years and haven't had an oil leak problem.
Originally Posted by 59f100mike
(Post 14681106)
I think Spuredon , Hiball covered the long Answer. But if you feel the need, the part number would be one of these two choices depending. https://cimg6.ibsrv.net/gimg/www.for...d3587f724f.jpg |
I think the dizzy from the Inline 300 I installed had an "O" ring. Question is what happened to 2nd half of your gasket?
Originally Posted by Damifiknow
(Post 14682660)
That's the likely answer. Need to replace the vacuum advance as well... Once that arrives, I guess I'll pull it again and make a thin gasket for it.
My distributor locked up on me last week. Ordered a rebuilt from autozone. $60 with no core charge. I got it yesterday. Came from Mexico, looks like a brand new unit. It has the o-ring on it like a newer distributor, so no gasket. Hopefully I will get to put it in tomorrow.
Originally Posted by 1960fordf350
(Post 14689515)
When it locked up it did shear the pin. It turns out I was tightening the lockdown to tight. With that rubber gasket, it sets the depth also. The gear was actually rubbing the block and pushing upward. The new distributor is actually 1/8 inch shorter on shaft length, also raising the gear. The old distributor shaft comes loose if I pull down on it. If I push up on it will turning it, it locks up. Even if I wasn't too tight, the drive gear cut pushes upward on the shaft as it turns. No pics, I already have it in the truck.
So, in conclusion, I'd measure my distances to make sure you don't waste a distributor like I did. |
(Post 14697115)
2 Attachment(s)
FAA-12143-A .. Distributor Base Gasket / Obsolete
1952/53 215 I-6 / 1954/64 223 I-6. ----------------------------------------- B9TF-12143-A .. Distributor Base Gasket-Rubber / Obsolete 1957/59 272 / 1957/64 292. |
I ended up tracing the area and making one to fit.
