1960 F-100 For Sale
The doors are solid. They are starting to rust a little on the very bottoms, but are still easily fixable. Cab corners have been glassed in. The Fenders have had some fiberglass repair, too. The bed is solid except where the the braces are, just in front of the rear tires. Some metal has been riveted in. But they did a good job. I can't tell if a new floor has been put in the bed, but if they did, it looks good. The seat has no tears in it. The clutch is super tight, and it shifts great. It starts very easy, and runs and idles very well. The wiring needs to be completely redone. It has a 9" rear end, but I don't know the ratio. I do know it will lay a nice set of posi's in first gear. The front and rear springs are in great shape. The shocks look new too. One of the rear spring shackles has had some welding repair. It's a 223 six, 3 on the tree. I gave it a fresh tune up, and changed the anti-freeze and thermostat. The truck is NOT drivable. It has absolutely ZERO brakes. ZILCH, ZERO, NIL. NOTTA. This is not a perfect truck by any means. It needs a lot of time and work. This is a restoration project. If you are looking for something to nit pick and point out all of the bad, then don't waste either of our time.
Truck is located near Leslie, MI. I can't figure out how to load pics to the site. But if you send me a pmail with your email address, I will send you plenty of pics. Or, shoot me text with your email info. 517-410-0592 The price is $1200.00. But I probably would negotiate with a serious buyer. Thanks for looking- Steve |
