Factory rim question
Hey Guys,
I have a question on what factory rims will fit a 2013 Ford Edge Sport. We had an Edge limited with 18" facotry rims. I have an excellent set of Toyo G02 winter tires on them & want to know if the 18" factory rims will fit a Sport model with 22" rims? Bolt spacing is the same but Ive been told the hub center may be different. Anyone that can confirm this? Thanks Mark |
center bore should be the same, shouldn't be an issue. I will measure the center bore of the 18" wheel this afternoon and post what it is for ya
Joe |
Thanks. I found the info online.
Both 18" & 22" rims have a 70.5 bore. Only difference is the offset spacing 39 on 18" rim. 44 on 22" rim. |
ok, cool
I wouldn't worry about less than 1/4" BS change...should be good to go! Joe |
