This is a good one 6.0l no start.
Okay back again and have done a lot of work since last post but still won't start. So far this is what has been done:
New stand pipe and dummy plugs STC fitting New Cam and Crank sensor New HPOP New Low pressure oil pump New (8) fuel injector New ICP and IPR New FICM New Batteries New Starter Oil pressure system checks good with shop air Fuels pressures verified 62 PSI (blue spring upgrade) verified fuel flow at filer housing, lines and rails. 6.4L banjo for fuel rails Good ICP pressure will get to 1100+ PSI Good IPRv and IPR% KOEO and during cranking Good FICM VP, MP 12/12/49 Good SYNC during cranking I'm in the Military so I will leave for a while and come back and when i get time I work on the truck. I took it to a local 6.0L specialist in Jacksonville NC Tripple C diesel for diagnosis, then heard some pretty depressing things about their shop. All kind of businesses trying to get over on Military folks. They couldn't figure out what was wrong. They said they fired it up and it would shut off at exactly 998 RPM but if they kept it above that it would run pretty good. it had no injector buzz when I took it to them KOEO so that lead to the injector replacement (that was their only recommendation). BUZZ came back after. I originally took it to them because I definitely feel it is an electrical issue and didn't have anything besides a SGII to diagnose it. They did also note something interesting as I did though........the ICP volts are at 4.0v+ and should be .08-.28v KOEO. they said that was fine HMMMMM. Like I said this is a good one, the ICP volts could be due to a miss-wired pig tail replacement so I think I need to figure that out. (would that cause a no start? still doesn't start unplugged) Its like there is no fuel getting to the injectors, no smoke, no attempt to kick on. So that is why I think electrical. This is aggravating really. I can't think of anything else so hopefully you guys can assist. HELP!!!!!!!! |
Sounds like you threw everything but the kitchen sink at it. With all that work it will be almost impossible to figure out without getting all the vitals of the truck.
Sounds like it doesn't it, but every code has been eliminated. the truck has 171K miles on it. Ran great before the no start. SGII was the best investment but still ran into a wall. Besides APR studs I'm trying to bullet proof this truck.
Have you tested the low oil pressure yet?
You listed FICM voltage at 12/12/48.
Was that low side and high side at koeo or cranking? |
Yes oil Low oil pressure is good. new LPOP
What year is it?
Unplug the ebp and see what happens. Check fuse f2 22 Unplug vdf and see what happens. |
That is KOEO, lowest volt for FICM VP and LP 11.5 and and the other starts at 49V and during cranking goes to 48.5 but after gets right back to 48 volts. From what I know of FICM all those volts are Great.
FICM volts
Originally Posted by Restlesswildman
(Post 14590367)
Originally Posted by cheezit
(Post 14590384)
What year is it?
Unplug the ebp and see what happens. Check fuse f2 22 Unplug vdf and see what happens. Where is F2 22 fuse? |
In slot 22 of the cjb
Fuses are good in cjb
(Post 14590407)
Did you try starting w/ the ICP unplugged? Vloney posted up a situation a little while ago where he had a truck that wouldn't start w/ the ICP plugged in and the issue was actually a bad injector coil. Granted there were codes that might have given a vague clue, but I didn't see where you checked for codes w/ something other than the scangauge (and I wouldn't really rely on it for code reading).
Also, a FICM can read good voltage and still be bad. Only sure way to eliminate it (IMO) is swap out w/ a known good one. |
ICP unpluged
Originally Posted by bismic
(Post 14590577)
I understand you changed the ipr. But with the amount work done maybe check the ipr screen again. Easy to send junk through it after any work done to the hpo system.
