Jhow88 |
08-17-2014 12:45 PM |
88 4.9 oil pan / rear main
So i was confident my rear main was leaking and the clutch was gone. I have the transmission birthed (my first - I'm handing out cigars) and the clutch components out and the flywheel ready to go to the machine shop. Everything went awesomely smooth :-jammin. But turns out the rear main is fine (I'm replacing anyway) but the oil pan appears to be seeping at the dip right under the rear main. From everything I've read the engine needs to be raised to change the oil pan gasket but is that safe with the transmission removed? Where should i go from here?
Edit: forgot to mention .. 2 wheel drive long bed
