Looking for Suggestion on Backup Lighting
I have done a search but nothing that i have found is exactly what i am looking for. I am looking for ways to increase the light behind my 2014 F250 when backing up. I have read about lights on the hitch, in the bumper on the rear or replacing the tail lights. I am looking for suggestions on what you have found to be the longest lasting and best solution for this
As you know, whether is a Dodge, GM or Ford the OEM backup lights meet the fed regs and that’s about it. There are several (many) aux backup light kits, some look better than others (and if it’s a work truck, who cares as long as it lights up everything) and several have posted their approach as well. I took a bit of a different approach.....while I do periodically tow (my 65 mustang on a tandem trailer), I wanted something a little stealthy that would work and look as if it was oem-.....while the flash on the camera reduces the actual effect, I mounted 2- 55 watt lights under the rear fenders, mounted in a manner to project out at a 45 degree angle down & away from the vehicle. Activated by a 40 amp relay & mounted in the front drivers side kick panel (& actuated through the vehicles backup lights), we used the oem wiring harness & access ports to provide all the routing. Utilizing lighting techniques used by rescue personnel (indirect to reduce/eliminate possible blinding as compared to law enforcement who uses direct lighting to see evidence), the lighting projects approx 2-3 feet from & completely around each corner on the truck and because the mounting location is above the top of the bumper, light is reflected onto the hitch area as well (you can see the reflection on top of the exhaust tips). The aux lights are visually hidden, protected from road debris (including flung by the tires) and turn on automatically when placed in reverse. Power to the relay is obtained through an unused 20 amp circuit at the fuse box.
http://www.f150online.com/forums/mem...aux-lights.jpg http://www.f150online.com/forums/mem...aux-lights.jpg |
I added a set of Tuff led lights using factory holes in the hitch. The lights are in a flood pattern. I have them wired into a switch.
Tucked up and can only be seen when kneeling down. http://i169.photobucket.com/albums/u...pstwgyerqj.jpg http://i169.photobucket.com/albums/u...psun6sisug.jpg http://i169.photobucket.com/albums/u...psob3pccbl.jpg |
Originally Posted by 96grimreaper
(Post 14575579)
Originally Posted by R.Parker
(Post 14575894)
How do you like this set up? also do you know which lights they are?
They are Tuff Led lights. I bought them from Amazon. http://i169.photobucket.com/albums/u...psif03mie1.jpg |
Very nice grimreaper.:-X22
Here is what I did.
I bought a set similar to these: http://www.4wheelparts.com/Lighting-...&t_pn=WAR63816 and tapped and screwed the mounting bracket into Hitch mount bracket. I hooked them up to one of the up-fitter switches so I can turn it on whenever I want. I suppose you could wire it to your reverse lights. I usually have to change them every few years when they burn out but there are plenty of light choices that cost more money and will probably last longer. http://i5.photobucket.com/albums/y19...psf6c8353a.jpg http://i5.photobucket.com/albums/y19...ps0d8c1e8f.jpg |
Ditto for me:
https://cimg2.ibsrv.net/gimg/www.for...f78e7f6046.jpg These were inexpensive and light up the ground very well, 9 years and still burning strong. They are connected to the backup light circuit, but soon they will also be connected to one of my custom upfitter switches along with the camera for better night time trailer hookups. |
I had the same set as the above lights on two trucks and they finally rusted out. I replaced then with some $25 LED flood lights from ebay, they are awesome!!
http://i76.photobucket.com/albums/j2...ps25870119.jpg I also have replaced my backup bulbs with retro solutions 9W LED's so it is like day light back there with both of these on! |
Originally Posted by Trophy_23
(Post 14578408)
Mine are upfitter only. They are zip tied on with HUGE zip ties, that hold on a right angle bracket from the old lights. They are 'hung' from that bracket. Maybe this picture will help show how they are mounted.
http://i76.photobucket.com/albums/j2...psuqbmeaql.jpg http://i76.photobucket.com/albums/j2...pspijyoqvt.jpg |
These have served me well for many years and are very reliable
http://www.napaonline.com/Catalog/Ca...375_0212867560 |
Originally Posted by Redrkt
(Post 14578758)
Mine came with zip ties to mount them with and I was skeptical, but they have held well for 9 years without getting loose, sliding, or breaking.
I've read some things that lead me to believe it would be OK to feed them through both the reverse light circuit and an upfitter switch, but unless I can confirm that I will probably use a diode or relay to isolate the 2 circuits. |
I don't use reverse for long time periods, just the normal back up to a trailer or back a trailer into a spot and done.
With that said I am thinking of installing something like a headlight bulb in the stock reverse housings. I will never have the reverse lights on long enough to cause any heat damage and I think it would be great light. (I am an OEM look junky) The only alternative I am entertaining is grafting a fog/driving light into the rear tail light housing so it can handle the heat but still have the stock look. |
