easiest way to drain front fuel tank
long story short.....its full of gas:-X16
I tried a siphon pump in filler neck but must have something in it I cant get the hose all the way in. |
You could pull the filler neck off the tank and try and siphon it out. There is room to get at the front one without dropping it.
Drill a hole
Bendover:-roll
switch the selector to front tank, take the line off the fuelpump, and put a high flow electric pump on the line. hook to battery, and pump it out.
