Suggestions on Dolphin gages in 52 F-1
I am about at my wits end trying to make all the stock gages work correctly in my 52 F-1.
If I cannot trust the temp, oil & gas gages to give me the correct readings I just don't think I can live with it!!! I really would like to keep it stock looking but don't think it is possible for me with 12 volts on a 302. I have the electronic voltage reducer on the gages but still not getting anywhere close. Anyone using these? Any suggestions? TractormanBill |
1 Attachment(s)
I have them in my '51 and they seem to work perfect. Dolphin's instructions/owners manual is pretty much non-existent though. You will have to alter the sending unit if you're using the tank behind the seat since the bolt pattern and diameter mounting plate on the sending unit doesn't fit.
My last '51 used an under dash oil pressure gauge and an under dash temperature gauge which also worked perfect. Both trucks were converted to 12 volt systems with "modern" engines. Hope this helps. Wally |
Bill, the stock gauges will work fine, look for NOS or good used. If they didn't work on 6v they won't work on 12v.
gages
What is NOS?
Anybody used the NVU gages? TractormanBill |
NOS = New Old Stock, Ford factory replacements still on the shelf. Since the '51 - '52 gauges were used into the '60's on bread trucks, there are a surprising number of NOS units still around.
Originally Posted by wallster
(Post 14557592)
My last '51 used an under dash oil pressure gauge and an under dash temperature gauge which also worked perfect. Both trucks were converted to 12 volt systems with "modern" engines. Hope this helps. Wally You can get an adapter plate to match up the new Dolphin sending unit. Speedway Motors has the part: 1935-1956 Ford Fuel Sender Adapter - Speedway Motors, America's Oldest Speed Shop Dan |
By the way....I also put in the Dolphin gauges. I haven't had any problems either.
https://cimg6.ibsrv.net/gimg/www.for...ac5c89df2c.jpg Dan |
Originally Posted by tractormanbill
(Post 14558203)
What is NOS?
i put the Dolphin's in my 48. The gas guage is a little lazy but so far they are working OK.
https://lh6.googleusercontent.com/-G...no/001-014.JPG |
