Need help
Ok I'm haveing lots of trouble with my truck no clue what's wrong with it but I'll list the symptoms
Ideals at 1500rpms At full throttle it will only climb to 3000rpms Going uphill at all I have to put the truck in second gear to avoid stalling Truck sounds like it is skipping I thinking that's just a spark plug went out though |
Can you explain to us when these things started happening and in what order? Have you done any repairs to the truck recently or did anything bad happen while driving/off roading?
Have you pulled the codes? That's the first place to start. You have multiple symptoms but you may only have one thing going on. Getting any codes is the first thing to do.
Originally Posted by 1995F150XLT4x4
(Post 14553056)
That's terrible someone butchered the wiring. All I can say is, start with basics.
1. Pull codes. 2. Check fuel pressure. 3. Get a Chilton or Haynes manual. Either or both is still far better than nothing at all. Most generally, both cover what is needed to do diagnostic checks and general info regarding fuel and electrical. 4. Address problems one at a time and PROGRESS. 5. Post each problem with corresponding checks. 6. Use the Search function or Google corresponding problems for other problems members here or elsewhere have encountered. 7. If all else fails, consider parting it out. You'll come out better $$$ than selling or scraping. |
