electrical problems
i have a 2009 f-250 king ranch 4x4 with a 6.4L. i have been having a series of electrical problems with no luck locating a source. Current problems: windshield wipers will not work at any selection, blower motor inside cab for a/c and heat will not come on, headlights in auto mode will turn on and off rapidly during daytime, speedometer will bounce when stopped and while driving at random times, when using keyless entry to unlock truck my side mirrors starting adjusting outward. i have checked fuses, relays, random wire bundles. any suggestions at this point would be greatly appreciated.
Did the body module get wet at all? everything ties into that module, I had a leak in my windshield which lead down to the kick panel and had to have it replaced, dealer only cause it has to be programed for your truck or VIN I should say.
electricla problems
The body module did not get wet that I am aware of. I have a feeling that it is a device that all of these componenets all go back to.
if there's water coming in
https://cimg4.ibsrv.net/gimg/www.for...50bd1590b.jpeg
this square is behind the fuse panel,when parked on a hill ,water ran in and caused a real mess with my electrical system.From what u talked about to a no crank ,no start problem,and codes out my a$$. https://cimg3.ibsrv.net/gimg/www.for...ddc7de4def.jpg this hole was to be covered at factory,drivers side was covered but not this side.should trim the tape. hope this might help,worked great for me.. hope this works,never done this before. |
