Turbo surging in 4th gear only
When I am driving down the highway my turbo will surge. I can watch it on the gauge going from 25 down to 20 and right back up it will do this until I let off or change gears.
Is this normal for a stick shift? Changed the fuel filters and nothing changed. Thanks. |
Sounds as if the vgt and or turbo needs cleaned.
Can you monitor VGT , MAP, EBP ? do have EGR or delete
Unplug ebp. Does it still happen? If so suspect bad vgt sensor. Swap in kowen good one to test.
Stiction only (mostly) happens when the engine is cold.
Once you have warmed up it goes away. It's more like a miss or ruff idle. Sean https://www.ford-trucks.com/forums/p...ctureid=149188 |
Would there be something electronic causing this?
I tried it again on the highway last night, all gears pull perfectly besides 4th... If I have to pull the turbo I will, but id prefer not to! I will pull the EBP sensor today before I head home and see what happens |
Originally Posted by 2006powerstroke90
(Post 14549629)
Took out the EBP sensor, thing was plugged solid, cleaned it and no more surging
Glad you got it fixed. And thanks for coming back and posting what resolved the issue. That cheezit seems to know what he is talking about.lol
