1988 f super duty?
I just got one and am shocked at how heavy its built. I can't find much info on it though. Any info would be appreciated.
Originally Posted by kurtis1971
(Post 14541831)
:-X25 |
all F-superduties were delivered from the factory as 2 wheel drives.
there were a few companies that did 4 wheel drive conversions on them , the most popular probably was Marmon-Harrington. you can pretty much get anything you need for the truck by asking for parts for an 88 F-350, except for the rear axle and parking brake assembly. that is a dana 80, and has either 4.56, 4.63, or 5.13 gear ratios. |
(Post 14541831)
Known at the time as the "One Ton Plus." It sports a HD frame,the hydroboost brake system w/ 4 wheel disc brakes.Though they are 2WD trucks,they are equipped with 4WD transmissions but,rather than a transfer case,they come with a drive line emergency/parking brake. A HD dana 80 rear axle that came from ford with gear ratio options intended for two purposes; heavy hauling & towing.They came in various wheelbase lengths with up to a 15,000 LB GVWR.It's widely known as the F-450 equivalent with many auto stores listing parts under either name. These trucks are easy to spot with their pickup size cabs,yet unique F-Super Duty fender emblems & 10 lug wheels. axle code 72 = 4.63 axle code 73 = 5.13 |
thanks for all that info
Here is the vin #2fdlf47g4jcb13803. I hope that helps. I need to find a repair manual. also if someone knows where to look.
I need a banjo bolt for the brakes but no one seems to have any.
(Post 14546898)
DORMAN Part # 484188 for the washer. (according to rock auto and amazons part finder.) |
Enjoy your real Super Duty! A truck when Ford still made TRUCKS, my buddy has a 1995 F450 and compared to my 2004 F350 its makes my truck feel like a F150
galaxy S4 using IB AutoGroup |
(Post 14544842)
kurtis1971, 2FD - Ford Motor Company of Canada L - GVWR 14,001 - 16,000 lbs F47 - Super Duty G - 7.5L J - 1988 C - made by our Canadian friends in Oakville (Ontario) These trucks can (and often do) last a lifetime. I'd suggest you invest in some good Ford service manuals readily available on the internet for pennies on the original dollar. :-X25 |
