95 powerstroke chassis 69 crew cab swap
posted both places need info
well i have always loved this body. i love the powerstroke. alot of work has been done to the chassis on the 95 as a bonus it is a 4x4 and od trans 3.55 gears new brakes hardware rebuild rearend.... alot of $$ in it. the body is trash so i got a line on the crew it is 300 miles away so the tape measure. is a long distance affair. i need a tow rig for my 35 ft camper in the sig line the chassis donor is there also. can anywone help enlighten me on the issues i know wheel base is differnet by 6 inches the 95 is longer. so whacking, weldig and plating the frame will have to be done or maybe sliding rearend. also cutting the shafts. anyone know the bodymount differences. also wiring but that will not be that bad i want a/c i will creating the firewall to get clearance on the downpipe and a/c box. are cabs diffeent widths?? any help would be great |
I hope you are a REAL good fabricator.
I have seen this done with a 95 reg cab/69 reg cab And also on a 03 crew cab / 96 crew cab. BOTH were huge projects |
