auto experts c4/6-aod questions
my question is directed to the auto experts in the house
my understanding is the AOD is basically a retooled C-4 is this correct or just a rough statement if it is a retooled c4 , if it can be done , how much modification or what needs machining needs to be done to fit aod guts to a c6 main body housing the reason is I have to modify some part of aod at some stage as its to go behind a 400 and that has a big block bell housing bolt pattern and I have the c6 to suit already , but to modify the aod to suit means cutting off the bell and buying a jw conversion bell but the main bodys of the aod are as I stated above are meant to be a retooled c4 and look very simular to the c6 in the body |
Nope.
Not even close.
About the only similarity is Ford. An AOD can be made to fit as you said by removing the bell housing. AOD uses a planetary and a few clutches similar to an FMX. Pan bolts will interchange. |
