Saginaw pump is in. Luxury living!
It was difficult to find the pressure hose, but I went thru the buyers guide at NAPA, and found only one that has the right fittings(3/8 male inverted flare and 5/16 male inverted flare). Going from manual steering to this is absolutely wonderful!
The pump and bracket is from an early 80s E150. http://i565.photobucket.com/albums/s...pszswdnpr2.jpg http://i565.photobucket.com/albums/s...psuldfhrzb.jpg http://i565.photobucket.com/albums/s...psolqejq1f.jpg |
This is what the pressure hose looked like before I bent it to work with my setup:
http://file.autopartoo.com/oeimage/s...715_164656.jpg I did not buy the part from them, it was just an online image search for that part number(GATES 355550). |
I picked up a full Saginaw pump and everything I need to swap mine over to it.
Haven't done it yet though. |
Hey Dale, nice job. What's your Saginaw steering gear out of?
I upgraded my Bronco from the stock Ford unit to the Saginaw, and it was a night and day difference.
I can't imagine going from manual steering to one! Nice work. :D |
I can get a steering gear from an '82 F150 but I'm not sure if it will swap into my 66 F100. I understand my steerinng shaft will be too long and I'm willing to have it shortened but I don't know if the gear will swap in there or if I need something from am earlier model. I checked out the Tech Article on the Fordification site but it onlt mentions swapping in gears up to 1979. I don't know if that means you can't use one from years beyond then.
Right, only up to 79 fits a 65-79. Mine is from a 75 F100. The column is from a 74 F250(manual trans).
Saginaw box, Saginaw pump, and next up is hydrobooost. I just ordered a slew of parts to do a disc swap, and Astro van hydroboost. Then, shave the head to up the compression. Final step is a ZF5 swap. |
Originally Posted by nevrenufhp
(Post 14602294)
Saginaw box, Saginaw pump, and next up is hydrobooost. I just ordered a slew of parts to do a disc swap, and Astro van hydroboost. Then, shave the head to up the compression. Final step is a ZF5 swap. thanks. |
Originally Posted by Old Coyote
(Post 14601759)
I will be going with a saginaw pump in 80. It came already mounted to the cummins diesel. I can't wait to see the difference. |
when i put my new steering gear and motor and zf5 in, then ill be putting my saginaw in.
