steering wheel column lever
Ghost writer here new member I have a 2003 f-150 4×4 5.4 I saw your comments on the shift lever I did everything on there the 2 bolts , adjusting the little wheel under the column everything stayed ok but the lever is still loose when on park I still can wobble around in that park area does anybody know to take that wobble off it drives me crazy knowing that there's something wrong with my baby. Please help
Ghost writer |
Welcome to FTE...moved to greater assist you in your issues
If the Torx bolts are tight, then the bushings in the shift tube are probably worn out.
