4 speed trans mount
I have been looking for the mount for my 4 speed tranny and have not been able to find one does anyone know where I can get one or how to make one?
1 Attachment(s)
21A-6068-A .. Rear Rubber Engine Mount / Reproduced by Carpenter.
1948/52 F1. Lower pic, C = F1. |
If you want answers to questions as vague as this you need to provide info, e.g. what year truck, what motor and mount set up, what type of 4 speed, get my drift. Can you weld, bend metal, skill level, etc.... You want help, provide us with the proper tools to help.
Originally Posted by jonesa49f1
(Post 14469286)
Patrick |
Yeah it is the rear trans mount mounts to the frame my mount the rubber is all rotted out and when I took my motor and trans out the mount fell apart.
Post your location in the upper right hand corner, you do it by going through the control panel you used to sign up for the board. If you have your location posted there might be someone in your general area, or immediate area, that can help with working on your truck and locating parts.
You can also list your truck, year, model in your signature. (see below) This will clarify what truck(s) you have. You can install a signature through the control panel. |
https://cimg4.ibsrv.net/gimg/www.for...7bc52f78f6.jpg
Big crossmember/trans mount Is this what you need? my cell is 636-489-9742 Patrick |
His frame is OK, he needs the replaceable mount.
If you are looking for the long rubber piece joblot has them. I just got one a few weeks ago
Unless I'm mistaken, a 4-sp in an F-1 uses the same semi-circular mount as the LD and HD 3-sp's. Only the trannies in F-2 and F-3+ have the deep crossmember.
You are probably correct Ross
I was looking through a couple of web sites over the weekend, one stated that their rubber was only for the F-1 three speed while another didn't differentiate between the two, just sell "all".
Here is a thread with pictures: https://www.ford-trucks.com/forums/1...l#post10483970
In it, MTFlat shows a HD 3-sp in an F-1 with the same semi-circular mount as a LD 3-sp. And Havi shows a 4-sp in an F-1 that uses the same. The rear bearing retainer was changed for F-2 and higher to use the "hoop" crossmember with the flat rubber mount. |
Look at post 2, the rubber mount is illustrated, as is the parts catalog applications and part number.
