Things you find under the hood of your truck
http://i823.photobucket.com/albums/z...psfc597353.jpgI found this light under the hood of my 50 f1. Appears to be an old back up light. What interesting things have you all found?
I forgot to mention the big round horn that mooos like a cow. It still works and I like it.
Found a mechanic more ingenious than me had created an adaptor to get a small paper air filter to fit the old carb in the place of the old oil bath filter. Still have the oil bath unit and like the looks of it better, but had some carb issues and had to get a better filter. I would like to find new wiring under the hood to replace what I have.
Originally Posted by Skalywag
(Post 14458116)
Originally Posted by abeagle
(Post 14458273)
Every single, stinking wire was yellow. And not a single solitary solder joint to be found anywhere. Just twisted ends and electrical tape. :-hair |
(Post 14458273)
https://www.ford-trucks.com/forums/1...r-cleaner.html |
beagle
Have you considered modifying your oil bath unit to accept a paper filter? I found some instructions on the net on how to do it and am much happier with the original filter look but paper filter innards. If you can't find it get back to me and I can post some pics of how its done Bill oops-I guess I should have read the whole post--that's exactly what I did with mine too BTW--my engine ( running well a year ago before he painted it according to the owner), had paper towels stuffed into every intake and exhaust opening that had never been removed. mOf course I never believe that "running well" story either. |
I found a quart of oil wedged between the firewall and inner fender, ATF bottle stuck between core support and headlight, a rat skeleton behind the throttle linkage by the carb, and a oily old rag stuck in the fan belt.
Looks like Tye the TruckGuy has the best list of things found so far. The previous owner usually says the truck is in great shape with no issues and you can't miss if you buy it. Guess the PO just added a few extra things for the price.
Bruce |
I hope to find a running engine! lol.
Actually, in a 1972 F100 from some years back, I found a propane carb set-up, and a 110 outlet/inverter box that looked original to 1972. I kept the inverter box. Someday, I'll dig it out of storage and see what brand name is on it. |
