Just finished 5,160 mile trip with high egt's
I have a gauge for just about every monitorable parameter, Just finished a 5k mile trip from florida to Minnesota to black hills and back to florida While towing my 11k TT through chattanooga, the highest my eot got was 240 going up the highest peak on I-24 but my ect was 204-216 depending, and eot average was 220, although going up I forgot to turn my a/c off.
My EGT's were averaging 1000-1200 I never gave it second thought as I was always under the impression 1300 was where you wanted to stay away from . After talking to several people including some forum members here that this was playing with fire and is too hot, I ordered a custom tune from gearhead and utilized the unlimited tow with powermax customization, it didn't help, it was still 1000-1200 I just tried to keep the rpms up to help cool the motor, I'm at a loss. Should I try 8k tow will that provide more boost to get more air flowing into the motor? |
What do you have for exhaust?
Sent from my leash using IB AutoGroup |
4" turbo back
Where is your EGT capture point? What oil do you run?
1200 is too high? If you pull over and shut down it damn sure is... |
1300f before turbo is the upper "safe" limit for sustained running. It's possible to burst past that for a short period, like a few seconds.
When having a conversation about EGT, make sure everyone is on the same page and talking pre-turbo or post-turbo. Post turbo will see 200-500 degrees less, so 1100f doesn't sound so bad post-turbo until one realizes that it might be 1300-1600 pre-turbo. Bone stock it seems 1200 is the ceiling for temps from what I have seen. Put a tune on it and 1400 is easy to get just doing 0-60. Josh |
Originally Posted by diesel_dan
(Post 14447028)
T Think your EGT is more for Inject Prob then turbo
rare a Turbo burns down from heat Lessover time is always a Bonus But pre turbo you sound close what did it run before |
and is EGT same as other temps cold soak
Originally Posted by Bullitt390
(Post 14447065)
Originally Posted by BLADE35
(Post 14447628)
just something that needs ruled in or out
ID say say your fairly close not knowing the terrain in which it was tested or MPH |
