91 5.8 Best Headers For Low End Torque
Brand? Shorties? Longtube?
This engine will be lucky if it goes over 4500 RPM, so I want a set that is good from idle to around that. I thought I knew what I was gonna do but those headers are no longer avaiable so looking for new info. Thanks in advance for any info |
Don't know much on brands but if you want torque go for long tubes. They make a noticeable difference on torque.
Long tubes
I have hedman mid tubes and they're adequate. Great fit, but definitely tight by the frame rail on a big block. On a 5.8 you'll probably be fine, but on my 460 I had to unbolt the engine and jack it up a couple inches
Originally Posted by Plowboy34
(Post 14445851)
This engine will be lucky if it goes over 4500 RPM, so I want a set that is good from idle to around that. I thought I knew what I was gonna do but those headers are no longer avaiable so looking for new info. Thanks in advance for any info :-X22 |
F350 headers are discussed a lot here. But over rated hardly. I've never seen a hi-po motor go into a car with manifolds. The flow rate is far better than regular manifolds, and the try-y headers help with the scavenge affect.
