1973-1979 ford truck parts
Newest addition:
1977 F150 Exlporer 1973 ford F100 short box. bed is not available. 1976 highboy 4 x 4 ranger xlt 1976 4 x 4 1977 3 speed manual transmission 1977 c4 1976,1977 c6 1973 c4 (needs to be rebuilt) 1976 divorced transfer case 8' Beds (2) both need some work 8' Ford Bedliner 1973 ford 302. Running 40,000 mile since rebuild 1976 351 M engine with Mickey Thompson Valve Covers 1977 351 Cleveland engine Cabs (Total of three) 1973,1976,1977. all need work. doors and door parts, fenders Radiators and supports Tailgate 73, tailgate parts Exterior trim, grills, and grill inserts, bumpers Brand new fuel tank used tanks, behind seat tank 3 sets of 4 hubcaps for 1973 and 1975, Dana 60 rear end, Dash pad decent, dash, dash pad cover wire harnesses from four trucks, Two brand new condition exhaust systems, Steering columns and wheels, Seats 1977 f150 8' frame 1976 4 wheel drive frame 1973 f100 short bed frame body replacement panels for fender and cab (4) 33/12.5/16.5 Centennial Canyon Climber mudder tires |
ford truck parts
You have any 460 compatible stuff? I need a radiator and shroud, as well as brackets for power steering and alternator. Maybe a few other smalls. Thanks
Need a steering column
Is the 76 4x4 a 150? Is it automatic with power steering?
Lariat460
The 4 x 4 is a 250. The Custom is a 150 but 2 wheel drive
Lariat460
both power steering
Steering column
Is the 250 an Automatic? Is it a Highboy? You list 2 - 76 4x4's. Do you know if the length of the shaft in the column is the same for a highboy and a regular 250 4x4?
the 250 is a manual. The higboy steering is sold
i am desprate for a 360 fan shroud for my 73 f250, please message me if you have one
got any pictures of the 335 series cleveland? Also, what size radiators and condition? pictures of the beds...how much work do they need and what are you asking for them? What part of Mass are you in?
How about a exhaust manifold plenum heater valve for my F150 300\6 of 78 vintage? And tan door panels too, maybe... the PO made wooden ones that do the job but, you know. I get a lot of grief bout em! And you wouldn't have the top bracket to hold on to the heat shroud for the intake heat pipe? That'd be awesome if you do! 54896. Oh, and a good chrome bumper without the bracket holes that they put on some models.
hermancm
I currently do not have any of those parts.
Dash bezel
How about a good dash bezel? Preferably wood grain, non AC and radio slot not cut up. Thanks!
Do you have a manual transmission pedal set available? I'm also looking for the complete clutch linkage assembly and manual trans steering column.
do you have an air cleaner assembly for a 4bbl laying around and what would you want for it shipped to 44420? If you have a 4100/4150 carb I might be interested as well.
I have a 1978 f250 ranger 4wd. would you have rear end links that will work for me?
