F150 4.6 2v Supercharger-Turbo
Hey guys i got a 2003 f150 4.6 2v. Looking into getting a supercharger or turbo setup for like under 3 grand only want like 5-7 pounds of boost. any ideas? #f150
bump . . . . . . .
bump......... sorry, just doing the same build, so hoping to get some info..
I can tell you now that a supercharger won't be available for under 3 grand. At least, I've never found one. However, turbo charging might work well for that motor. It's all about how you set it up and what kind of things the motor needs to do.
I'm gonna build one of these for a ranger hoping to get an 11 sec car while keeping it a daily, so ill be doing big turbo and big cams. That will put my power band at a better for racing 5000rpm band. But If you are towing you won't necessarily need cams or a big turbo, just a slight timing tune and some decent twins should give you a good low end build. It's all about what you are wanting out of it. |
Custom building a turbo setup will be your cheapest route.
Find an oem turbo, and buy quality wastegate and bov, you should be fine. 3k is a good budget. I could build you one for that cost if you were closer to Philidelphia PA. |
You still build kits?
I’m fairly close to your area. I just joined and have been looking for a way to get some HP AND Torque under my hood. I’ve got a 2007 F150 with a 4.6L 2V engine . I know this post is a few years old but I figured I’d at least try to see if you build these kits still and if you could do one for me. I’m in Baltimore. Thanks
Originally Posted by UNTAMND
(Post 14844258)
I could probably build you a kit if you had a spare vehicle. I'm busy with my full time job, and don't have much garage space currently.
I'm looking to move into a larger shop soon, so it would be a good project once I move. |
