Ford truck brake controller
I want to put a trailer brake controller in my 05 Ford. Does any one know if it has under dash connections for the controller. I don't see anything am I missing them? there is a plug near the back bumper. That tells me something should be up front. Any thoughts? Stan
hello
I have an 05 f350 with a built brake controller. I get no voltage out of pin 4 which is the battery charging pin to the trailer on the 7 pin connector. I do get reading at the other pins. im doing the check with a voltmeter. what can I check why im not getting a reading at pin 4. thanks |
Originally Posted by stan'37
(Post 14356084)
On my '05 EX there was a grey plug wire tied to the dash frame up behind the radio that the patch cable from Tekonsha plugged right into then into the brake controller. My EX is more like the '04 trucks so I'm not possitive if the plug color or location was changed with the SD changes in'05. |
Originally Posted by paddler65
(Post 14356224)
hello
I have an 05 f350 with a built brake controller. I get no voltage out of pin 4 which is the battery charging pin to the trailer on the 7 pin connector. I do get reading at the other pins. im doing the check with a voltmeter. what can I check why im not getting a reading at pin 4. thanks You will get more attention and have a better chance of good answers if you post your question in it's own thread in either the SuperDuty forum or the Trailering Forum, trailer wiring isn't specific to the V-10. Good luck! |
(Post 14356084)
And yes, one of the other sections is a better place for info rather than this V10 area. |
(Post 14356224)
hello
I have an 06 that has the trailer brake controller wiring sitting in the glovebox. It has a plug in connector with the wires that connect to the controller. I presume under the dash there is a factory plug that this just plugs into? My 08 F150 had this and it was simple to hook up a controller.
Yes, it gets plugged in where I was indicating behind the drop down box thingy.
