What is the pitman arm bolt size?
I have spent about an hour trying to find this answer and even read through the FSM.
I have a 1974 F350 2wd with power steering and need to get the pitman arm off. What is the nut size? It is bigger then 1 1/4 since that is the largest socket I have and it wont fit. Thank you for any help you can provide. |
1-5/16....
This is a nut: http://www.marinestore.co.uk/Merchan...nut_metric.jpg This is a bolt: http://www.hobbysubmarines.com/image..._1000_inch.jpg |
Originally Posted by HIO Silver
(Post 14336026)
1-5/16....
This is a nut: http://www.marinestore.co.uk/Merchan...nut_metric.jpg This is a bolt: http://www.hobbysubmarines.com/image..._1000_inch.jpg 1 5/16" would not fit on mine. I noticed that it was a bit torn up by some previous owner. I tried filing the rough edges to no avail, and just got a 33mm. |
