Carburetor Base Plate Adapter
Hi Folks,
I am looking to use a 2-Barrel to 4-Barrel adapter on my 302. I have a Weiland 4-Barrel intake that I had a 4-Barrel carb on that didn't work very well on it. I am looking to put my stock 2150 Motorcraft carb to replace it until I have the funds for a new 4-Barrel. Summit sells a carb adapter (http://www.summitracing.com/parts/ctr-85-065/overview/) that says it works for a square bore 4 to a 2-Barrel Holley carb. I am wondering if the 2-Barrel Holley has the same bolt pattern as my 2150 Motorcraft? A.K.A will this adapter work for me? |
I have not used that specific item, but I did install one from Mr. Gasket with no problems and cheaper $30?. I did remove the EGR plate from carb.
Both the Holley and Motorcraft 2 bbls use the same bolt pattern
