fancyvern |
04-11-2014 11:23 PM |
Brakes
I have a 1999 F-150. This sounds funny but my brake pedal goes to the floor if you push hard enough but I have good stopping power. I have installed a new master cylinder ( bench bleed it), replaced rear brakes. Made sure the rear calipers pins are free. Checked front calipers and the pins are free also. Bleed the system 3 times. The unit stops good but the pedal goes a long way. You can pump the brakes forever and the pedal never gets solid. I thought the first master cyl. was bad so I put another new one on and it is like the first. No brake or abs light on the dash comes on. Any clues as to what is wrong?
