door trim
Stephen Dazey, no crew cab trim, just supercab upper trim.
I'm in need of a shifter stick with knob for a 78 f150 with the NP435 trans. Do you have one?
How about a '74 manual steering box?
SORRY
TD1932 No manual steering box 96red4.9 No shifter stick for NP435. |
looking for air cleaner box for 302 w/2 brl ?
Do you have lower racetrack trim for the bed LH back corner for a 79 f series?
LH back corner trim
BKSMN-I will check for that piece of trim.
bedside trim
BKSMN
Sorry, I don't have that piece of trim. |
air cleaner
what about the air cleaner ?
:-huh |
air cleaner
I believe I have an aluminum one. What engine do you have?
Originally Posted by john81chevy
(Post 14741139)
air cleaner
trepid94
I believe I have one from a 78. I will double check. |
that would be great
Do you have the section of the engine side wiring harness that goes from the firewall to the coil/distributor/oil pressure sender/temp. gauge with all of the connectors intact? I am needing one to work with a '76 V8 wiring harness.
wiring harness
JeepScrambler
I have a wiring harness off of a 1978 f100. Truck did run and harness looks complete although I did not look to see if the wiring for the rear tail lights was attached. It has had some work done to it according to some splicing that is present. Oil pressure and temp connections are intact. Has duraspark module with it. I will try to get pics if you want. $45 plus shipping for entire harness. |
