1973-1979 parts for sale
1973 to 1979 truck and 1989 E350 van parts
I have several items for sale ranging from large body parts down to small knobs and trim pieces. 360 engine parts 351M engine parts Supercab headliner, rain gutters, and dent trim. Steering columns 1 ton rear differential-(non dually?) AC pieces/parts Jr West Coast Mirrors. Interior parts Just ask for what you need. Thanks |
Front drivers side fender in good shape?
700hauler, I have a drivers fender for $45 bucks plus shipping. Decent shape with only surface rust. Will send pics if interested. Thanks
definitely interested. Sent a pm with my email for pictures. thanks!
Do you have a 78-79 steering column? It needs to be for an auto w/ p/s. Also am looking for plastic or metal glovebox insert
Steering column for manual trans? Need clutch pedal & linkage, too.
My 78 is an automatic the manual wouldn't work. Sorry
Nuts. Mine is (currently) an automatic, too. I'm swapping to manual with my Cummins. Thanks
If I was the one to drive it everyday it switch to a manual too. my wife drives the 78. I have my dads old 74 stick shift no power anything.
Automatic Column
Dentsides, I have an automatic column out of a 1978 f100, but it has some play at the bottom of the column. PM your address and I will get you a total with shipping if interested.
Clutch pedal and linkage
speedyweasel. No manual column. I have a clutch/brake pedal setup with linkage, BUT it came out of a 1971, not sure if it will fit the 1973 to 1979. $30 plus shipping if you're interested.
I can't pm yet. This account is too new. My zip code is 88026. John81chevy
Is it the lower bearings that are loose? Also does it have power steering? Mine has loose bearings, bad turn signal switch, and the previous owner broke the plastic Bezel below the wheel, causing a wobble... |
Do you have a GOOD center ac vent discharge hose for a 78 f series ?
steering column
Dentsides, Yes it is probably lower bearings. Column was in a city owned truck, but I believe it had less than 100k on it. $90 including shipping to 88026.
JWC 3, I have the flexible duct for the center (dual outlet) AC vent. Can send pics if you want. $30 plus shipping.
