coolant green..yuk. It may also be an issue.
Hello Stanley!
Thanks for your answer! I also thought, that the head gaskets are blown. But I did a CO2-Test on the coolant bottle/degasbottle. And there is no CO2 in it. If the head gaskets are blown the high pressure in the coolant system comes from exhaust gases, that are pressed into the coolant system. Exhaust gases are CO2 - so CO2 should be in the system if the hg are blown. When I coldstart the engine and let it run on idle for a couple of minutes (I tested up to 20Minutes) there is no pressure in the system - everything works fine up to ~190℉. But if the temperature reaches ~195℉ there is high pressure on the system. Don't knowing what the problem is, I drive the truck for ~7000mls with this symptoms. I think with blown head gaskets the engine should have gone the long way to nirvana... Or do I have completely wrong thoughts? |
Originally Posted by Mr Boogie
(Post 14209493)
Hello Stanley!
Hello everyone!
You guys helped me so much, I have to give you an update. I checked my thermostats and deleted them. Without the thermostats I drove for some km and there was the same problem. Because of the high pressure in the system my radiator starts leaking. Now my truck is in the shop. I ordered some new Viktor Reinz head gaskets, A.R.P. head studs, mishimoto radiator, updated upper hose and new thermostats. I hope my truck will work fine after repair. Do you think I have to update anything else? Greetings Philipp |
while the motor is out check the idler and tensioner pulleys for excess wear.
Thanks!
I already changed them 15.000mls ago. |
Sounds like you covered everything. That's pretty close to what I did last year. Problem is 2000 miles later I got hit in the rear by a drynk driver and she totaled my truck. So, keep an eye out for drunks. }>}>}>
Hi Stanley!
In your signature you write, that your engine was bulletproof -> what else did you do on it? My truck is also deleted (EGR & DPF) and tuned (H&S). Maybe I need a tail-pushbar... :-X04 |
(Post 14252083)
Hi Stanley!
6.4
my truck has been doing the same thing. did you loose ac when the water was coming out of the cap?
I am also having this same issue. the only thing different is I live in northern Indiana and I noticed this winter when under acceleration I get heat. when I pull up to a stop light it gets very cold again. Think mine is head gasket also?
classic sign of a headgasket issue.
Pressure test the system. Be sure that you have coolant in the degas bottle when cold. |
I have done a pressure test of the coolant system and it held up. no lose of pressure (cant remember how high we took it) and I keep adding coolant cause I am scared its going to run low so it stays well at the line when cold check it every couple days.
so look at the drivers side wheel well. At an angle you can see into the side of the radiator. See if you can see any evidence of a leak there.
Also it might be a good idea to replace the degas bottle cap. A $5 dollar part but then eventually do not hold the pressure like they should. 16 lbs of pressure is what you should be seeing. Any white smoke or sweet smelling exhaust? |
looked in there a few times havnt noticed anything special. also have went through 3 caps just cause its cheap and common with no help. theres is a few puffs of white smoke upon a very cold start like in the 10-20 degrees and goes away quick. I don't notice and sweet smelling exhaust. and I sure love the smell of diesel fuel!
