ZF 6 speed swap
For anyone looking to swap a ZF 6 speed into a 1999-2003 F250/F350/Excursion with a 7.3 Powerstroke, I have 99% of what you will need to perform the swap.
Rebuilt never used ZF6 speed (Rebuilt by National Transmission) NV273 (manual shift) transfer case (opened by National Transmission and inspected and re-sealed) Shifters for both ZF6 and NV273 Front and Rear driveshafts (believe they came off a long bed crew cab, but I can measure them if needed) PCM for the manual transmission 7.3L NIB South Bend clutch kit WITH the pre-bled slave cylinder/master cylinder (South Bend doesn't do that anymore) NIB Flywheel (came with the South Bend clutch kit) Complete clutch/brake pedal assembly Complete Manual Steering column Oil Cooler lines from the transmission to the factory oil cooler Aftermarket oil cooler Remote oil cooler thermostat I would prefer to sell this entire setup for one price so I don't have to hassle with separating it out, and this would be a great deal for someone who would like to put a manual in an Excursion. This was actually my plan which is why I have all the parts. But, as in life, plans change. The only thing that you may need to complete the swap would be a tunnel out of a manual truck since the tunnel in the automatics was not the same size. Please feel free to contact me with any questions/prices/pictures. 303-324-1541 Regards, Chris |
Do you still have this for sale?
Originally Posted by davidh11
(Post 14632090)
Thanks. |
