Look forward to it.
That China VCM is so tempting... Josh |
Originally Posted by Bullitt390
(Post 14176663)
Look forward to it.
That China VCM is so tempting... Josh Sean :-drink :-fire |
Originally Posted by Yahiko
(Post 14176697)
Glad someone is. I really don't want to do the work.
Sean :-drink :-fire Josh |
(Post 14176806)
It's a lot easier than pulling intakes... Josh Sent from my Telegraph using IB AutoGroup |
Originally Posted by MisterCMK
(Post 14176870)
Pulling injectors?
Sent from my Telegraph using IB AutoGroup Josh |
(Post 14177012)
Yep... Josh Pulling the intake isn't that bad. Maybe I should finally do something about my injectors... Sent from my Telegraph using IB AutoGroup |
(Post 14176806)
Josh
(Post 14176870)
Pulling injectors?
(Post 14177012)
Yep...
Josh to install my BPD EGR cooler. I talked to the people over at Fugate Ford. They did head gaskets before I bought it and anytime the heads are off they clean the turbo. So I won't have to do that unless I want to with the way I drive. While the intake is off it's going to get a good cleaning to remove all the carbon/soot. I do have an intact EGR system but it's turned off with a tune. Right now I guess I should go out and do that relative compression test. Truck is nice and warm for the Costco run and dinner break. Yes dinner at Costco Chicken Bake. Yummy! Sean :drink :-fire |
(Post 14177187)
Hmm.
Pulling the intake isn't that bad. Maybe I should finally do something about my injectors... Sent from my Telegraph using IB AutoGroup 1) Passenger side the lower 2 VC bolts if you don't have a 12mm flex ratchet wrench 2) Passenger side oil rail is a biotch without a stubby torx bit or at least a mini 1/4" ratchet 3) I hate removing the FICM brackets for whatever reason. As for intakes, that part isn't bad, I despise re-installing the turbo no matter how many times I have done it. Josh |
(Post 14177255)
3 things suck about injectors: 1) Passenger side the lower 2 VC bolts if you don't have a 12mm flex ratchet wrench 2) Passenger side oil rail is a biotch without a stubby torx bit or at least a mini 1/4" ratchet 3) I hate removing the FICM brackets for whatever reason. As for intakes, that part isn't bad, I despise re-installing the turbo no matter how many times I have done it. Josh Sent from my Telegraph using IB AutoGroup |
Ok I went out and did my last little test.
Here is the screen. Sean :-drink :-fire |
(Post 14177332)
Good info. I may have to polish my spool valves in a couple of weeks here. How long do you think it takes?
Sent from my Telegraph using IB AutoGroup Props to ya if you decide to change out the upper injector o-ring, that sucker is a bugger to change out. Josh |
(Post 14177255)
1) Passenger side the lower 2 VC bolts if you don't have a 12mm flex ratchet wrench 2) Passenger side oil rail is a biotch without a stubby torx bit or at least a mini 1/4" ratchet 3) I hate removing the FICM brackets for whatever reason. As for intakes, that part isn't bad, I despise re-installing the turbo no matter how many times I have done it. Josh On the turbo, the biggest pain IMHO is to align the exhaust on the turbo. Found that loosening the pipes at the exhaust manifolds made it real easy. |
You know if you look at the two images
#7 is low in both. Now how they relate I have no idea. Sean :-drink :-fire |
Worn rocker?
Josh |
Do 3/7 share?
Sean :-drink :-fire EDIT : I must be half asleep. I was reading firing order not locations. |
