Keypad entry
Does anybody know if there is a way to get the factory code for the keypad on the door without going to the dealer and paying $45 for them to pull the code? I bought the truck used, it's an 04 FX4
Have you looked really close through the glovebox, owner's manual, etc. to see if the factory code card is wedged in there somewhere?
They didn't give me an owners manual when I bought the truck, bought used. Somewhere I thought I read that the code would be on the computer but maybe I'm blind but I didn't see anything.
Take off the rear seat back rest and panel and you'll see the control box for the keyless and your factory code on the white label. The seat belt bolts are T 50 and I believe there's more on this in the tech page on FTE or Google er!
Awesome I'll do that. Thanks a bunch
Originally Posted by TritonF150
(Post 14154579)
Good thing is, once you get the original code, you can reprogram your keyless entry to whatever code you choose. |
Awesome thanks for advise will do exactly that as soon as I find my T50 torx bit
There is a tutorial on youtube showing a very easy way to get the back seat off .
and this only works if your key pad is factory , my 04 came with a card with the code in the owners manual , but it is add on not factory. |
Is there a way to find out if it's factory or add on?
Originally Posted by '04 FX4
(Post 14170880)
if there is a hole cut in the door, then the keypad is original
if the keypad is double side stuck to the door...then it's still OEM Ford, but installed afterwards. |
If code not there, search on here about code retrieval-someone posted a spreadsheet that has all combinations and said it only takes about 15 min find right code
I don't know how to put a pic on here
(Post 14171715)
It's factory install not add on, but I can't get my fat arm through to pop the clips off...lol just my luck
