throttle
Anyone know where I can get factory(stock) throttle linkage for 1950 f1??? Need from pedal to carb--mine has flathead 8--Im in oho,thanks
Have you posted in this site's wanted section? Jag
There's one on eBay for $25: http://www.ebay.com/itm/like/331061649884?lpid=82
DW |
throttle
Have not went to parts wanted yet,looked at the add for the 50 throttle linkage and his add said came off 50 woody ,it has the 2 bolt bracket to the firewall==mine has 1 hole each side pedestal type,found another in the add,but has been welded on==will keep looking--mine totally missing.I think the linkage to the pedal is part of the bracket and a separate rod goes to the carb.?
The eBay item is a car piece. There's a 6-cyl truck piece for 48-51's on eBay that could be re-worked, but I'm sure someone will have the right piece. It is all one piece of rod bent at both ends, with a center tube crimped over it that the pedestals fit onto.
Is a 51 the same? I'm in Ohio and I have a 51 f5 with a v8, but I do not know the 48-52 trucks what fits and what doesnt
As long as it's a V8, it will fit. Only the 6's are different, and 48-51 is different than 52 in the 6's.
Throttle
Originally Posted by bigwin56f100
(Post 14083232)
Originally Posted by johnglock45
(Post 14086497)
Kevin, I live in ohio not (OHO) AS I POSTED but im sure you knew that, anyhow I need all of the throttle linkage,from the pedal to the carb if you have it.Sounds like it will fit from what someone else posted,let me know what you have and how much. thanks, John----I live around the Dayton area--cell 937 313-1694
