08 Expy EL Limited washer pump location
Hello all... Need to replace my windshield washer pump and I was wondering if someone could tell me where it is located?
Thanks! |
Mounted to the washer reservoir.
CAUTION: When servicing the windshield washer pump be careful not to damage the windshield washer pump seal. CAUTION: Do not operate the windshield washer pump before filling the windshield washer reservoir. Failure to do so may result in premature pump failure. 1.Remove the RH headlamp assembly. 2.Position aside the shield as necessary to gain access to the washer pump. 3.Disconnect the windshield washer reservoir hoses. 4.Disconnect the windshield washer pump electrical connector. 5.Remove the windshield washer pump. 6.To install, reverse the removal procedure. Matt |
Thanks for the info, I think I have the same problem and likely need a new pump but want to make sure.
I disconnected the hoses and made sure they were clear / check / all clear Before I go directly replacing the pump motor is there a fuse that I should check ? I looked at the list of fuses in the owners manual and did not see any reference to a washer pump. |
