intake worth it?
09 F350, I have done the DPF/CAT delete and using a SCT tuner. Im running it on level 3 that does not require a new intake. My question is, If I plan to stay at that level (which I do) is a new intake worth it? I don't want to spend $200-$300 just so I have it. Is it worth it? Pretty happy with mpg and power now.
If you're not sucking in the air filter indicator and throwing a code you are good to go. To answer your question, No. I have a H&S tuner with a stock air filter and run the 250hp mild tune and have not thrown a code "yet ".
It is nice to be able to just clean the filter rather than replacing. I doubt you'll see any notable differences one way or the other.
Originally Posted by irsparki
(Post 14001147)
Originally Posted by KR250
(Post 14020896)
250 Hp mild tune.... Huh?
Doesn't matter what tune.
First mod should always be a some type aftermarket intake. So far I'm very impressed with No Limits. Name says it all. I think it would be the best. |
(Post 14020896)
Are we talking about a air intake or air filter, the original air filter is good up to a 250 HP tune or better, like said above if your not sucking the filter minder and getting a code it's a waist of money.
Originally Posted by bubbasz1
(Post 14023361)
Originally Posted by UGA33
(Post 14022283)
I would consider Spartan's version of the 250HP mild.
It gets aggressive at the 275hp file. This is Spartan tuning. Others may be different. I towed a lot with the 275.
(Post 14024062)
I have no doubt you know more about these engines than I, but a 250HP tune increases the HP on 6.4 by 71%! What would you consider aggressive?
I'm pretty sure he was just saying what H&S goes by WHICH is stock/mild/wild....<~~which is your hot damn tunes ...I FINALLY HAND CALCULATED...with exhaust/ aFe stage 2 intake/ mini maxx "mild" 250hp setting I'm getting a steady 11.5 mpgs in town... BUT I'm on 6' and 37's/20's..so it obviously would be better if I we're stock.. so I can feel the power added from the intake/sounds better too just not sure as to how much you really gain from an intake!
You're crazy if you think a "250HP" tune truly increases HP by 250. I've been running the 300 by H&S for quite some time.
Originally Posted by RM2738
(Post 14028807)
