Front Spring Perch Bushing
When changing the front, perch/frame mounted spring bushing, do guys usually press/drive them out and then the new ones back in with the perch in the truck?
Or do you have to grind the rivet heads and replace the perch? Looks to me like it could be done in the frame. |
Originally Posted by Steve
(Post 13994566)
Yeah I figured. I'm going to a big swap meet tomorrow, so maybe I'll see one. As for the bushing, I might cobble together a pressing tool and see how that looks.
Definitely in frame, can be done no problem.
Threaded rod with nuts, some flat washers, a piece of pipe works fine, in and out. Grind washer OD to fit.
