2002 diesel ~ emission PROBLEM light illuminated
1/16 update for JASON & STEWART (PD's ) below...
As per owners manual 2002 F350. page 9 & 218 The light to which I refer is a EMISSIONS SYSTEM LIGHT. To the others who have responded with helpful advise.... Thank you. Before I take my truck in for service can anyone give me a clue as to what I'm facing... Diagnosis & Cure? 2002 diesel dually... (130k miles) I was in Indiana in extreme cold (sub zero) drove to Florida --it sat for 2 weeks in 80 degree temps. It was problem free all the way to Florida. When I started it (after sitting for 2 weeks) the emissions problem-dash light came on. The truck was stuttering and bucking...as I stepped on the gas pedal it acted like it was going to stall. I shut it off. Later started it problem free. Today as I drove at 40-50 mph the light came on... The tach was bobbing up and down...the entire truck was bucking like it was going to throw me threw the window. Hardly had enough power to get to my destination. two hours later it was fine... Until 5 hours later... As I approached a stop light... Light came on and I had to turn on my flashers as the truck was only able to go about 20 mph...bucking the whole time. Any idea what's going on here? What a mechanic might tell me... When I take it in for service? I had oil change & air filter change at walmart before my trip to FL. I added SeaFoam about 10 fill ups ago. Otherwise I have never had problems with my truck. Hope some one can advise me. Regard, Kimberly. |
I would bet you $0.50 you have a UVCH problem...search "50 cent mod" and I bet you'll find the solution.
Agreed. It's not really an emissions warning light you're seeing. It's the check engine light. From your description, it sounds like another loose UVCH.
Read this thread. https://www.ford-trucks.com/forums/8...ck-shakes.html (or at least the first part of it) |
Originally Posted by F350-6
(Post 13959124)
To the OP, like Tom and Chris stated, you have classic symptoms for a loose UVCH. Stewart |
Originally Posted by ztruck
(Post 13958980)
Originally Posted by HKusp
(Post 13959840)
She Stewart, she....:-X22
I completely missed the sign off. Stewart |
(Post 13959840)
As per owners manual 2002 F350. page 9 & 218 The light to which I refer is a EMISSIONS SYSTEM LIGHT. |
Very very sad. (PD)
(Post 13959840)
(Post 13960585)
(Post 13960589)
I have heard it called all sorts of stuff....CEL (Check Engine Light) .....SES (Service Engine Soon)..... ESL (Emissions System Light) and the infamous IBS Light. (I broke S***). Either way.....sounds like a UVCH (Under Valve Cover Harness) problem, and Chris linked the best write-up I've seen for it. :-X22 |
(Post 13960585)
As per owners manual 2002 F350. page 9 & 218 The light to which I refer is a EMISSIONS SYSTEM LIGHT. All kidding aside, like Tom posted above, that light is called the SES light, or DTC light, or CEL light, etc. Stewart |
(Post 13960585)
It is my understanding that any PC monitored emissions control component that will adversely affect emissions when out of range is required to illuminate the engine light. (EPA mandate). There are a ton of DTC (diagnostic trouble codes) that do not illuminate the engine light because they do not affect emissions. This is probably why the manual calls it an emissions system light, although I, like most, have never heard it called that because I have never read the owner's manual.
