Temp Question
Hello everyone, Ok some of you know I was tackling the job of changing out changing out my lower thermostat housing. I have completed the job. I bought the part from amazon it was the lower and upper thermostat housing with a thermostat already in it. I got it replaced. Took me about 7 hours total taking my time. However, I have everything back together flushed the system twice and now have replaced with coolant and distilled water. NOTE I did replace both temp sensors also. Now I drove it for about 30 min and them temp never gets above the bottom line of C. I dont know why. Its either a issue with the thermostat or the sensors. Has anyone else come across this issue before? I know the vehicle is not over heating but it should be half way between the C and H lines. Any help or ideas would be appreciated. Thanks
Did you go OEM or aftermarket? Was one sensor a "sender" (one wire or two)? Did you burp the system?
When I replaced the heads on my '95 Aerostar, I thought I would do a good thing and replace the temperature sender (the sensor for the gauge that has one wire) even though the old one hadn't failed. When I fired it up and let it run long enough to get warm, I nearly had a heart attack when I looked at the temperature gauge. The temperature was way over what I was used to seeing, but not in the overheat zone. I had replaced the temp sender with an aftermarket unit. I put the Ford sender back in and the temperature went back to where it always had been. I haven't had a thermostat be bad right out of the box or cause a noticeable change on the gauge. And, I'm sure the sender I used was "within spec", but it was different enough to cause the gauge to read higher than what I was used to seeing. If the sender can be off in a manner to cause the gauge to read high, I'm willing to bet a different one could be off such that the gauge reads low, especially if you go aftermarket. You might be able to find a resistance vs. temperature chart online and compare that to what you're seeing. That might help, but you'd also need an independent means of measuring temperature. |
Originally Posted by Mikeman
(Post 13947275)
The sensor doesnt unscrew. It is held in with a wire clip. The sensor has an oring.
Do you get any heat from the heater? Are the upper and lower radiator hoses hot? If yes to both, try swaping with the old sensor. |
Originally Posted by sccamper
(Post 13950495)
Is the lower radiator hose and heater hoses getting hot? You may have an air pocket in the system.
(Post 13959001)
top of the thermostat housing is leaking looks like the hose clamp has broke off and is now leaking. So I am going to fix that. I have not checked the lower radiator hose. The heater hoses will get hot but not as hot has the top radiator hose. |
