Originally Posted by stainlessstroker95
(Post 13951639)
Thats gonna be one heck of a towing rig this summer Darin. Hope it all turns out the way you want it. At least till next winter haha.
Thanks Glenn, that is what I'm gonna do. |
Originally Posted by 427 fordman
(Post 13947882)
No, I bought them from someone on here and they weren't with them. There isn't anything special about them, is there? I had a 9/16 bolt with a shoulder/thick washer on it that fit well, so was going to look for 16 like it. Was thinking I'd loctite them in and be good.
Glenn, I think I got what you are saying. I'm gonna tackle this before I do any more work on the box in case I need to shim it to make the body lines line up. |
Thanks Brad. I'm going to town thursday and I was going to get some then. There is a small "v" cut in the rotors for the studs to go in originally, but there is a more solid hole under that (if you know what I mean). About half of the rotor hole has the v in it, the other half is just a hole. I was thinking a guy would be ok with a fairly normal bolt means that the v is only half way through the hole.
I worked on the body bushings today. Man, that sucked. I ended up cutting them all apart, only way they were coming apart.
I have a question. I put new poly mounts in, but don't have a complete solid bushing inside like the stock rubbers. The way I cut them is pushed up from the nut on the bottom with a jack and socket, then cut them in half above the frame mount. Except for the drivers side rear. That was terrible. It is by the fuel tank, so I moved the box back and cut the living crap out of that one to get it out. So I have most of the sleeve in the rest, but not all in there. I don't have anything mounted permanently yet, its just sitting on the new bushings. Is it necessary to have that complete metal sleeve inside the poly bushing? I can't see it being necessary, but thought I'd ask. I used the upper washer with the sleeve on it till where I cut it. The only real bad one was the passengers side rear one. It raised up about 3/4 of an inch. The body line was way off on the box, but now is just about right. |
The old chain and jake didn't work?
Originally Posted by oldbird1965
(Post 13969557)
I then said pi$$ on it and cut them off.. |
Those body mounts can be a huge PIA sometimes. I've had to cut them out before too.
Did you worry about the metal sleeve when you put the new ones in Bill? I just don't see it being necessary with the poly, maybe it is? Like I said, I used most of it with the top washer, but it got cut and using new bolts.
I've never installed poly body mounts before, but I think you would be ok without it. It is actually a two piece deal, one slides inside the other, I guess so the rubber mounts can give a little.
Good point. Originally they were made like that. Over time just seized into one. I think they will be ok too, I'm running with it.
Thanks bud.:-X22 |
I don't know how far you actually lifted the truck but I lifted mine until the wheels also came off the ground on the side I was working on. Pretty amazing how tight a flared two piece sleeve can hold together that strong. The directions say to grind that flare off when putting them back together so what was the point of the flare in the first place?
So theres a metal piece on top and on bottom with the threaded part the bolt attaches from the top in the bottom?
The chain or puller is pulling the lower part out of the upper? Im trying too wrap my head around this....if i ever get my bushings in...my buddy is killing me on these things.. |
Originally Posted by fordman67
(Post 13971475)
Glenn, I lifted the truck way off the ground and let it sit there. I sprayed PB in there, beat on it, etc., and had no luck. Finally said screw it and cut them all out. Didn't even try it on the middle ones. Front bolts broke loosening them. I didn't want to mess with the fuel tank strap, so I slid my box back (not mounted yet) and got at it from the top. I was able to pry the thick rubber part up and cut underneath it.
Wow, my tires were starting to come off the ground but not all the way off.
