EASY......RIGHT?
1985 F-250 460/4sp/4wd Engine from 1977 lincoln-146 tooth flywheel with 351M starter. Eating starters like cereal!! maybe 5 starts per starter, also tried 460 and 390 starters. Now with the second 351M starter- ate flywheel. Thought I had it worked out....need actual Ford know-how here. Many thanks.....
I apologize-need to get used to specifics with Ford.
truck: 85 f-250 4wd 4sp enigine: 460 '71 Lincoln D1VE6015A2B bell hosing:d7ta7505ad flywheel: 146 tooth 1st 3 starters-460, broke of nose of starter (started about 3 times each) Replaced flywheel- 146 tooth 9 inch clutch 4th starter-351M, stripped gear on starter-not the teeth, starter engaged/spun (started about 10 times) 5th starter-351M, ground teeth off flywheel after 4 starts |
Have you tried the 460 or '80-'86 forum? Probably find a lot more info there
